Discuss Help ... 2 different tiles joint don’t line up (assumed both 30x60 but not) in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Italy
the split face should be laid almost without spacers,
1 mm maximum, otherwise it loses the continuous wall effect.
therefore alignments separated from the other walls.
best solution would be to remove the split face and
Misalign widely from the other tiles.
Kcoh
Is it generally okay to lay tiles without any spacing or butted? Also do you think it is a good combination with the marble tiles? I have a feeling that they really don’t match up and should go with the marble tile for all the walls. Thanks
Italy
NO,BUT IN THIS CASE, YES
Also do you think it is a good combination with the marble tiles? YES, I LIKE IT
SHOULD NOT MATCH,
it is A WALL THAT MUST REMAIN DETACHED
FROM THE REST OF THE BATHROOM.
IT MUST SEEM A STONE WALL, IT MUST NOT
COMBINE WITH OTHER WALLS
Kcoh
Cheers guys. Thought a lot of this this morning on my way to work and decided to take it all off and start again. I’ll take into account your advices and update you of the outcome. Thanks again. :)
Kcoh
After removal photos. I think I need to press the tiles a bit more, although I did remove some tiles during the tiling and it seems they were fully covered. I used 12mm square notched trowel and back buttered. Also what is your thoughts on keeping the gloss tile row? The tile last tile is 15mm short of the wall, but would sealant hide this with the split face tiles against it?
4F240782-A4A1-4E49-8CAE-177115F5A486.jpeg 0CA09721-EDFB-47F7-BAD2-660C3EC86612.jpeg 6232709A-3274-4C23-8F9C-59F535A4E6F4.jpeg 31AEA9FA-F4D6-40CE-8577-D03EA4DAD379.jpeg F68DEFA6-60E9-4342-A11D-D1290876B1FF.jpeg 0082F454-0FFC-4958-A959-DB3C492086A0.jpeg
Reply to Help ... 2 different tiles joint don’t line up (assumed both 30x60 but not) in the Canada area at TilersForums.com
Northern Tiler
