Discuss Sigma 10M9 info please in the Tile Cutters area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Doozy
Quick one for those with this machine, how messy is it?
I mainly cut using a grinder outside, but hand on heart I'm getting bored with going up and down stairs umpteen times on some jobs. Want to add a reliable all round wet machine, but can't be doing with pools of water everywhere :closedumbrella::( :D
Andy Allen
Can't see you setting that up on a customer's landing...!
I just use a vitrex pro cutter....
Plenty of dust sheets down, plonk it on the landing, and crack on ...
Andy Allen
Simon Dale
A good machine sold mine a few years back :(:)
They're quite large, very heavy and very accurate and powerful.
They need catchment for run-off too.
I was going to get one, but plumped for a little (but also very heavy) Raimondi GS86. It's the best of both worlds for me. Portable and yet capable of anything you can physically get on it.
Basically a grinder blade wet saw which can be used dry if needed.
Doozy
The size (to a degree) isn't an issue. Looking at something that can go from say 1.2m straight cuts, to mitring 600s, to wet room envelope cuts all in one go.
But you must be working in some large properties .
Doozy
No, not really. More refurb/new build scenarios.
Like I said, cutting down the stair runs if poss. The Sigma ticks a few boxes, but I don't want to be sheeting up half the floor if it's throwing lots of water about
They don't throw water about really but it will run off the edges of large tiles and especially if mitering.
One big advantage is you can pretty accurately rip down 1600 planks easily even though the carriage will stop before halfway, you just keep sliding along.
For what you're describing I would suggest it's perfect.
I do a lot of similar properties where I have room to work and to a degree, make a bit of mess.
I just tend to use my grinder and large sigma rail cutters for 95% of everything and just occasionally a wet saw. But that's just the pattern I've got into I suppose.
Plus, if you decide it's not really for you, the resale value is brilliant and you'll sell it easily.
Doozy
That's a great answer, but interestingly throws up another thing I was looking at, maybe getting a good rail saw instead, but there seems to be limitations on that. Dust/water being one and I'm not convinced about the mitring results
Bill
He means a sigma rail cutter like this
https://www.*******************/pro...MIgYX27I3E4QIVyrvtCh0DgA9-EAQYASABEgJQU_D_BwE
or this
https://www.tiling tools/product/sigma-3e4m-max-professional-tile-cutter-127cm
All wet saws create spray - some more than others and wet rail saws are probably the messiest of them all but they have advantages too.
Reply to Sigma 10M9 info please in the Tile Cutters area at TilersForums.com
Midland Commercial
