Discuss Loose tiles & underfloor heating... in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
JMRolfe
Hi all
New to the forum so hello, please go gentle, and let me know if I'm posting in the wrong place?
We've recently had an extention, during which we also had the kitchen, utility and all three toilets refitted and retiled. The builders organised or 'did' all the work throught the build, which in hindsight was an error as we've since had a minor electrical fire, and two small leaks amongst other things :(
Latest issue is tiling. Tiles have been down 9 months without issue, but in the last two weeks we've had 5 tiles become loose, across 3 different rooms. Grouting is clearly breaking and coming out making them porous.
My main concern however is the underfloor heating. Presumably if the tile is moving, I'm risking the cables breaking?
Short of ripping it all up and starting again. Is there anything I can do? Unhelpfully we streached ourselves with the build, so with corrections to date funds are limited.
Upstairs floors are chipboard, followed by cables, screeding, adhesive, tiles. = 4 loose tiles, 3 of which in a group.
Downstairs is concrete, 6mm insulation boards, cables, screeding, adhesive, tiles. = 1 loose tile.
To my knowledge they used flexible adhesive etc.
Any advice would be very appreciated? Let me know if I've missed any details?
Thanks!
J Sid
could be a 101 different reasons, we need more info
what adhesive?
what primer?
what slc?
photos
straight onto chipboard is a no no
JMRolfe
Morning!
Not much to see on photos but please find attached?
I've also attached pictures of adhesive & grout.
Primer was 'Prowarm underfloor heating primer' which looked, felt, smelt like PVA glue??
Not sure what Sls is?
I'm thinking getting builders back out not really an option 1) if they didn't do it right the 1st time why will they the 2nd /3rd? 2) unsure if they'd even come back again. I see that as just being stressful to be honest
Very disheartened and fed up with it all tbh.
James
20190216_105013.jpg 20190216_105045.jpg 20190216_105112.jpg 20190216_110433.jpg 20190216_110347.jpg
J Sid
not come across that adhesive before, the spec says it's suitable for
Sealocrete Rapid Set Flexible Floor & Wall Tile Adhesive is a cement-based adhesive for use on concrete, concrete block, cement render and brick. It can also be used on plaster, plasterboard, chipboard, wood and existing glazed ceramic or vinyl tiles and is suitable for use with most domestic underfloor heating kits. For internal and external use.
big claims there :eek:
JMRolfe
I'd get onto the builder and also talk to sealoctete direct and get them to come out
In reality do you think it would get me anywhere calling Sealoctete out? I don't think I'd get anything but stress with the builders?
So are you thinking it's the adhesive at fault? I was assuming it was due to being layed on boarding? Although that doesn't explain downstairs with the concrete flooring...
Other than ripping it all up and starting again do I have any alternatives?
Time's Ran Out
You’ve asked and the replies seem to lead towards getting the builders back!
For whatever reason you seem reluctant to do so, but legally they have to have the opportunity to put it right.
Put everything in writing and keep copies, you will need it if action is required through the courts.
Your alternative is to live with it!
JMRolfe
How was the heating turned on for the first time, and how long was it left before turning the heating on for the first time.
Thanks all, was just hoping there was an easier, less stressful fix...
I was advised to leave it fro 3 days, then start it at 16 degrees and only increase by 1 degree per day.
In reality, the one that is worst was left at least 2 weeks before switching on, and has only been used approx 10 times?
To be honest if he doesn't want the builders back and is willing to pay somebody else to sort it , I understand him not wanting the stress as for getting sealocrete out I expect they will find something wrong with the install or instalation techniques so that will be their get out of jail card .
Waluigi
I would look for a local Tiler(s) to come out and give you some idea of what needs doing to rectify the issues. Even if you have to pay him to give you a quote or even a report on why he thinks it’s failed.
Then get the builders back out and ask them what they plan to do about the issues.
If the advise between the Tiler and the Builders doesn’t tally up then I’d go back to the builders and explain what the professional Tilers suggest.
Reply to Loose tiles & underfloor heating... in the Canada area at TilersForums.com
Dawz84
