Discuss Noob needs mitred tile edging advise in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Blunt Tool
Total doddle, it’s only the tilers that can’t cut a mitre in tile trims that have to mitre the tiles :p
On a more serious note have a search on here and you should find excellent videos showing how to.
It’s important to have the right kit, ie a good wetsaw with a good blade that can tilt to 45 degrees or grinder with a quality blade and diamond hand pad
And plenty of practice, get some old tiles, anything that’s not grey nowadays it seems and get going
Andy Allen
Pin hammer and a rubbing stone!
P
Perry
Yes John untill I brought my first water cutter 30 years ago. £700 quid then and fell apart after 3 months.
Blunt Tool
Grout line required?
The mitre is usually left 1 or 2mm from edge of tile so that there is no breakout and glazed edge remains intact. A joint is left of 1 or 2 mm where you can either grout or a preferred method of a 2 part colour matched resin filler to protect the edge and make it stronger. A slight sand and shape of filler will be required
Reply to Noob needs mitred tile edging advise in the Canada area at TilersForums.com
Dawz84
