Discuss *UPDATED* Wet Room Project Build Thread! in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all
In a kind of 'Payment' for all the advice i have got from here i have decided to do a build thread for my wet room, it may help someone in the future it may not but here it goes!
Room size is 1.8M x 2.2M, at the end of the extension i finished building a last year. I work full time so this may take a while as it will just be me doing this...
Screed is an anhydrite screed currently 50mm below finished floor level, i shuttered of 150mm before the screed went in to accomidate the drain.
With that let's start with the blank canvas.
You can see the shuttered off area here
Ceiling already plastered
And placing the toilet roughly where it will live..
So first up we need to get our services in:
Toilet Overhead Cisten
Hot/Cold for sink
Feed to Wall mounted shower
Feed to wall mounted wand flexi shower thing
The shower will be digital so also some Cat5
Planning the pipe routes
As i am battening and boarding (Didn't feel i could get the finish i wanted with the DotnDab) i only needed to recess the surface mounted clips to just below the batten depth of 18mm. So with that in mind:
Next up was making the copper pipework.
Now, i had no soldering iron but i can just about TIG Weld... Just Dan, just....
So making the pipes
And welded
Got slightly awkward lol
This was surprising! One bit of new old stock 15mm from 1989 and the other from 2018!
So with the pipework made i pressure tested it all to 4Bar...carefully...
Then clipped it all in place
Next up was the extraction, used a 100mm inline fan from Vent-Axia
Time to make a hole and get it mounted
Mounted in the void and 100mm hole drilled
Solid 100mm Cavity pipe inserted and flexi added to the end for the bend using aluminium ducting tape
And fitted
And sealed to the fan, just the wiring to do and the drop down for the fan inlet
Next up i drilled the holes for the spot lights, out came the trusty china laser level...
Nice line so the spots will be in-line...
Further updates tomorrow folks, got some more done, just need to edit it :)
Q
Qwerty
Thanks for taking the time to post this. Looking great so far & looking forward to the updates
WetSaw
Never seen copper pipes welded before! You might find it easier to get yourself a torch ( small gas bottle with a screw on torch ) and use Yorkshire ( solder ring) fittings. Run all the pipework and then solder the joints, probably would have saved you some precious time!
Looking forward to seeing the progress.
Ok bit of an overdue update!
So, marked out the spotlights with the laser level and cut the holes:
Next up i wanted to battern all the walls rather than d+d as i wasnt confident enough to get a good finish.
So batten at 400mm centers.
Also placed ply around the pipes so i can a good fixing point
So with the walls batterned out it was ready for the moister resisting plasterboard:
Added plasterboard adhesive along with the screws
Added the stop bead, this is where the plaster ends and the tiles begin
I next scrim taped and plastered the top strip to the beading
Getting the plaster up
Starting to flatten the plaster
And done
Left it for a week to dry then masked, painted and painted the beams
And ceiling done!
Next up got the Impey linear floor drain in and pipework connected.
Tray in and packed with cement, there is a membrane between the anhydrite screed and the cement
If anyone fancies tiling it drop me a message! Got an advert up but no hits yet, think it’s a bit small for a lot of you guys, I thought it’s a decent job then I realised some of the adverts were for 1000+ sqm :D
Spare Tool
After that lovely prep and attention to detail even behind the boards which is very refreshing to see, I would be in no hurry to pick the first tiler that comes along Adam, they want vetting with a fine tooth comb, beware of the chancers out there and take your time to find the right tiler to give that the finish it deserves.
K
Koomber
Bloody hell, that is a nice finish!
Also, somebody send this man a torch! Max respect for welding something as thin as copper pipe. I can solder, but my welding is awful, unless you want a hedgehog.
Hi guys!
Next up we have the floor! In the last update i go the linear drain in it's position. So next up was building the floor falls. I didn't want a tray because i preferred to make it. :)
So, the floor with Linear drain
So, time to remove the Anhydrite screed lattice.
Killer angle grinder!
And removed:
Next up was time to make the falls, 20mm per meter for the first meter to the drain then 10mm per meter for the rest of the floor.
Jig'ing and welding the former:
Wall Fixing
Former welded and in place
Side rails done
Rear Rail
Now i had a form in place to screed to i needed to primer the floor
Next up was the screed
First up i used Mapei floor adhisive to bond the screed to the floor/primer then a sharp sand 3/1 Mix with SBR.
Drain Masked off first of course
Here you can see the adhisive before the screed was compacted ontop
And done
Spare Tool
Lovely that Adam..only thing I would have done different is to set the drain around 100mm away from that back wall so it could have had floor tiles enveloped all the way around the drain, sure it'll look fab, great prep work
Reply to *UPDATED* Wet Room Project Build Thread! in the Tanking and Wetrooms Forum area at TilersForums.com
Dawz84
