Discuss ADESILEX P9 Over Ditra in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi Guys.
Tiling a floor next week over a suspended timber subfloor. I'm first putting Ditra down with an S2 Adhesive over the ply, then tiling a limestone floor. Whats you're opinions on using Mapei Adesilex p9 ontop of the ditra to stick the stone?
Q
Qwerty
I'm not sure if I remember correctly or not but don't Schluter recommend not using an S2??
On a timber floor Ardex AF200 or the like is far superior for adhering Ditra imo
Think you might struggle to get it right now. There have been some problems reported with AF200 (but not publicised)
I've used on good new timber floors with no issues though.
L
LM
I often use different brands tbh Mapei VS90 plus being one. Any of the main flooring brands equivalent adhesives do the same job. Ardex only recommend a couple of brands because they haven’t tested any others but I have.
What type of problems are being ‘rumoured’?
Not staying stuck!
L
LM
Not staying stuck!
Well that’s obvious.:rolleyes:I thought you might have heard something more specific as to why.
Could be something as silly as someone using it on screeds not dry enough or releasing agents on the ply.
You know how poor UK screeds and concrete floors can be. So following the instructions on the pot, they go and use it on unprimed, dusty, massively uneven floors and low and behold - the Ditra isn't stuck at all.
It's basically not idiot-proof.
In that case the AF200 hasn’t failed it just typical plonkers not following basic principles.
I always thought, from it's launch that it wasn't suitable for screeds and concrete. Timber definitely though.
L
LM
From my flooring background I know that for these types of adhesives to be successful on screed/concrete the substrate needs to dry and smooth and not too porous. Most screeds etc aren’t good enough because they are too porous , weak and friable, they aren’t compact enough. You could easily dig into them with a screwdriver etc. They nearly all need a coat of leveller to achieve a suitable finish. Problems also occur if the adhesive dries downwards and skins if you understand me. On a well prepared substrate once it air dries to the point were it becomes tacky to touch then it’s good to go and good luck trying to pull it back up again once it’s dried.
Saw that af200 when I went into ctd, what trowel do you use with it? Going to give isomax a try for the stone. Seen it on pro tiler tools for a decent price. Can’t work with rapid in summer though personally haha. Schlüter don’t recommend an s2 for ditra? Would have thought it would be even better when laying over ply.
Reply to ADESILEX P9 Over Ditra in the Canada area at TilersForums.com
Finias Coroama
