Discuss Tiling on a cardboard wall!? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Duncan
Hi,
I'm in the process of tiling a bathroom with 600x300 porcelain tiles (24kg square metre) and was planning to use wedi board (well an equivalent) for the plasterboard wall but it turns out the wall isn't a stud/plasterboard wall it's a kind of cardboard waffle/honeycomb construction so there is nothing to screw the wedi board to.
Are there any other options?
Also there are a couple of outside wall where all the plaster has come of leaving a rough (bit flakey) render
I was going to board this as well but would it be safe to tile straight onto the render if it was flat enough.
Thanks for any help received
Duncan
Photos attached
On one
In this circumstance (I would)
Scrape or steam off any remaining old tile adhesive and give the walls 2/3 good coats of diluted PVA, patch up any large holes and skim the wall with finish plaster.
And when the plaster is dry, prime with diluted SBR liquid and waterproof the walls to be tiled with a tanking liquid.
Not an ideal scenario regarding kgs/m2 though
Duncan
Thanks for the replies
No there is not enough room to do the 50x50/board option
Isn't it pushing it a bit weight wise to put these on plaster and the drying time is a bit of a problem too.
Do I need to go back and recommend lighter tiles?
Yes it is a new bath, fitted by the owner before I go involved
Duncan
Bond
Duncan
Bond
How about glueing and using toggle style fixings into egg box partition, cement render looks a bit friable. Lighter tiles are probably a good call.
Duncan
Hi Bond,
What are these toggle style fixing?
Yes the render is a bit s*** too.
I've not messed with it too much but I think it will be ok to plaster over.
All in all 24kg per meter tiles are not a good idea.
He's gone on holiday so I'll have to get in touch and tell him his bathroom won't be all lovely when he returns :-(
On one
The thing is......it takes what it takes(timewise)
It might take a bit longer to do it properly, but you have no comebacks on you.
Duncan
Yes indeed, it's just disappointing not to be able to do what I planned and I feel like I'm letting him down a bit.
Bond
Hi Bond,
WetSaw
What's the other side of the "cardboard" wall? Could you do anything the other side to be able to mechanically fix the wedi?
Reply to Tiling on a cardboard wall!? in the Canada area at TilersForums.com
Matthew77
