Discuss Efflorescence or Sealant problem on Indian Sandstone in the Tiling News; Tile News area at TilersForums. USA and UK Tiling Forum
Hi all, I have recently had an Indian Sandstone installed in Oxfordshire, after some thought I decided to seal it, we have parties, we have kids and I have clumsy other half.
I waited for around two months to see if there was any obvious signs of Efflorescence, I then washed the patio down left to dry for a few days, swept clean and applied LTP Mattstone as recommended on these forums and a few others.
Everything was fine until we watered a couple of plants and a couple of white spots appeared but nothing to worry about, then the rain arrived last night and today and I have quite a lot of white patches come from nowhere is it Efflorescence? or a sealant problem? any advice and recommendations would be really welcome.
Thanks in advance.
OP
A
adam72
Cheers, I cant seem to post pictures no matter how much I resize the image I am over my limit.
I followed the instructions fully with the sealant, what can I do to remove the white patches?
I am starting to regret this sandstone patio.
OP
A
adam72
I would insert images, however the site is not having it, I guess this is down to me been a new member?
OP
A
adam72
It was dry, it was only the other week during the hot spell, I applied to sealer during the early evening so the temp was lower and there was no direct sunlight.
Ajax123
What is underneath the tiles?
OP
A
adam72
I believe it is mortar, I was away when the work was done, I have contacted LTP and sent them images, they believe it is Efflorescence from the pictures I sent, they were helpful and have sent out a grout cleaner...lets see if it works.
Ajax123
So they're on a layer of mortar and they're outside?.
OP
A
adam72
yes sorry for the guessing game ,I thought I put down it was patio so yes outside.
OP
A
adam72
Well its looking worse after applying the grout cleaner, more of a milky film over the slab rather than the white marks and spots.
OP
A
adam72
Great I can add some images if anyone can advise that would be great
Before
After
OP
mike1979
Try some xylene or thinners xylene is used on patteren imprinted concrete to take away white patches in situations where sealer has been applied to a slightly damp area or if it rained after sealing it might be moisture trust me give it a try xylene is what really is needed you can get it on the web but try some thinners brush it quite hard and use a healthy amount it melts and heats the sealer a bit give it a go
OP
A
adam72
OK Mike cheers, do I apply this neat? do I just apply and let is soak in or wash it off after so many minutes? Cheers
Reply to Efflorescence or Sealant problem on Indian Sandstone in the Tiling News; Tile News area at TilersForums.com
mmcdon47
I've Disabled AdBlock
