I am tile the kitchen and took up the tiles, only to find another layer of tiles underneath. These are small square ceramic appx 4"x4".
This first layer is perfectly flat and very solidly attached to the wall substrate whch is plasterboard, dot and dabbed onto breeze block (70's built house)
I tried to lift one and it took the plasterboard underneath back to the brown paper.
I am retiling the whole kitchen and would like any recommendation on what https://www.tilersforums.com/forums/tile-adhesive/ to use, should I key in the tiles with a mini angle grinder to lay another tile layer on top?
The tiles that are going over them are larger and also ceramic.
So what https://www.tilersforums.com/forums/tile-adhesive/? and does it need priming, if so what primer?
Thanks in advance
Jon
Thanks in advance
Jon
